Originally Posted by Nasgul AFAIK, all 65nm CPUs require less Vc than 90nm. I think I've seen most 920s do 4.0ghz with less than 1.5v. |
Originally Posted by pauldovi What is the highest Vcore for the Preslers? Is it the same as for the Prescott's? Prescott is about 1.525 Presler - ?? |
Originally Posted by pauldovi I am at 1.375, but I was wondering how much farther I could push it. Temps do seem to be a problem because it is at 37C idle and 44 load. I have not had time to do full stress test on this though. |
Originally Posted by Adeoliver Your temps seem pretty good to me, @ 4.193 Im running a dual Prime95 @ 47c and thats with alot of Vcore. Your load temps are only 7c over your idle which means your cooling is doing a good job. BTW what kinda clock have you hit so far? I guess this CPU doesnt run much cooler then mine!! BTW I might have to get 1 just to see what the breaking point is. |
Originally Posted by uberjon what did your system cost you paul? i was recently lookin into buying one of those chips and the rest of the setup. but im wondering on if the prices will drop with conroe coming out or if conroe will be just as cheap??? could you like get me a list of everything u bought and where and how much? id rly apreciate it as my pc sucks and idk if i can afford to even buy one within the next 6 months!!! |
Originally Posted by uberjon xe model are you sure? they said they was done with ht and that price aint an ocer dream its an ocer wet dream ![]() ![]() |
Originally Posted by pauldovi I am running at 4.55Ghz (325*14). My goal is for 4.76 (340*14) as I think my memory and motherboard can easily hit that (DDR2-800, P5WD2-E Premium). I think my temps are safe upto about 55-60C Load. |
Originally Posted by Adeoliver I wanna see ![]() ![]() |
Originally Posted by Adeoliver Well if you got a validated Dump you can just sign in HERE and get every dump youve made ![]() BTW sorry about your family member. |
Originally Posted by uberjon ok. sorry for the bad grammer. by the way what kind of mobos are the conroe going to use? paul when your computer is stock about how much more faster is your computer than mine? like 1.5x 2x 3x? im thinking of going for a system like yours if i can get the money. but i want it to be compadible with vista/vista gfx card/conroe all 100% compadible. |
