1 - 6 of 6 Posts
i had never heard aboutv this processor but now i ve just benchmarked it.it did 5612 pc mark05.<br />
i hve to ask:there is sth strange about the freq .it is supposed to be clocked at 3.4 but cpuz shows me just2.4ghz on both cores.is this ok?<br />
thats my first approach to pentium d and i dont know the smallest thing about them.
Maybe it throttles back when idle to save power and reduce temps.<br />
I know my P4 and E6600 do.
you mean the benchmark has run @3.4ghz,hasnt it?
Post a screen shot of CPUZ.<br><br>
Anyways your CPU has EIST enabled, thats why it reads at 2.4ghz. Disable speedstep in the boards bios and it wont do that anymore, it is a power saving feature so no sweat!!
I don't think it's recommended to have EIST and/or C1E disabled. If any, it should be enabled at all times whenever possible.<br><br>
I have my 945 OC'd to 4.51ghz using EIST and no problem. It reads at 3.18ghz when idling and jumps to 4.51ghz when needed:<br><br><a href="http://s6.photobucket.com/albums/y218/Nasgul/PD945OCd.png" target="_blank"><img alt="" src="http://s6.photobucket.com/albums/y218/Nasgul/th_PD945OCd.png" style="border:0px solid;"></a><br><br>
BTW, <b>idi</b> what are you waiting for to overclock that Pentium D 945 to at least 4.20ghz? Preslers can handle 250fsb with stock Vc and practically running at the same temps as stock speeds.
Discussion Starter #6
thank you for the suggestion nasgul but that pentium d is not mine and the owner has ho intentions to oc it!<br />
main reason i posted this thread was that this was a "rare" cpu,it wasnt at the comparison chart of tomshardware.com.thats it!<br />
now i see 945 is a good ocer!<br />
thanx!
1 - 6 of 6 Posts
