1 - 6 of 6 Posts
What are your settings? The chart is wrong... it should begin higher at around 240MB/s and have a downward slope. A setting is off.
It could be a reporting bug. Try HD Tune as well and check your CPU usage.
I think the 32k stripe is probably behind the poor performance in the first plot.
Re-run it with 64k (or 128k as in your second dataset) and you should get different results.
1 - 6 of 6 Posts
