flakes out like crazy on what?
This mobo overclocks beautifully for me(I run 24/7 4.10Ghz 1.5v, NB2800 1.35v on Air).. no clue where you see a flake out
Even on Linux it works fine for me.. its just the sensors that don't work, at least the one I cared about reading "the cores temps" that is accurate(1 core reading is enough for me, since through windows all my cores run the same) - since I always run above 4Ghz I need to pay attention to only that... but I wished it detected everything rpms, voltages.. and all voltages through linux.. on windows side it detects everything & works awesome.
Eitherway as for the Linux OS running it.... works perfectly fine, lan, video(video editing), audio(also works fine on audio studio recording), even my CF(obviously ATI sucks on gaming on linux side, Nvidia is much more supported on linux) & every upgrade seems fine.... Even on OSX as well(my CF works Full QE/CI/CL on 10.6.4, wifi, Lan, sound, etc... just about everything)... so can you explain to me where does this Motherboard flakes out for you?
Let's not forget this board supports the SLI Nvidia patching... so its not ATI crossfireX only compatible.. after patching you can even 3-way SLI
Only board I hate since IT DOES FLAKE OUT is the 890 version which came out horribly bad... defective from factory, ton's have died on very simple overclocks, stuff getting fried, other had many ram issues(even using compatible rams), BSOD randomly even on stock settings & as well having issues of not letting them install an OS.. all sorts of issues happened on that board.. not even RMA solved them. If you go to the club you will read posts of people just giving up on that msi board and switching to the crosshair & some even going back to the 790 version.
So compared that board to the 790 version we both have... ours is beautiful
So, I ask... why do you hate this board "I hate this motherboad to be honest. It flakes out like crazy"?
Originally Posted by GodofGrunts ![]() I hate this motherboad to be honest. It flakes out like crazy and I haven't tried to do lm-sensors |
