1 - 1 of 1 Posts
Petra's Tech Nuke PHN Concentrated Biocide (10mL)
Description:
Nuke -PHN is a specially formulated Benzalkonium chloride solution intended for use as a biocide in your water cooled PC. Primarily geared toward systems running straight distilled water, Nuke -PHN is not acidic and will not drop your coolant's pH, making it ideal for use in poorly buffered coolants and situations where corrosion is a concern (since many corrosion inhibitors are optimized for use within a pH range of 7-8.5). However, we do not recommend the use of Nuke -PHN with most "pre-mixed PC coolants" and dyes (though, our testing indicates that there may be no compatibility issue with Feser's UV dyes). Do not mix Nuke -PHN with the original Copper sulfate based Nuke -Cu.
Instructions & Ingredients:
Use: Add 4 drops per 1L of coolant for approx. 2ppm
Active Ingredient: Benzalkonium chloride 1.65%
Warning: This product contains Benzalkonium chloride. DO NOT INGEST! AVOID CONTACT WITH EYES AND SKIN! KEEP OUT OF REACH OF CHILDREN AND PETS!
? If ingested, do not induce vomiting. Give plenty of water to drink and seek medical attention.
? If contact with skin occurs, rinse with plenty of water. Seek medical attention if pain or irritation persists.
? Contact with eyes can result in corneal damage--AVOID CONTACT WITH EYES! If contact with eyes occurs, thoroughly rinse eyes under tepid running water for at least 15 minutes. If sensitivity to light, irritation, pain, or swelling persists, seek medical attention immediately.
Details:
DetailValue
BrandPetra's Tech Shop
FeaturePHN Nuke keeps living organisms in a liquid cooling loop under control.
LabelPetra's Tech Shop
ManufacturerPetra's Tech Shop
Modelphnnuke
MPNphnnuke
PublisherPetra's Tech Shop
StudioPetra's Tech Shop
TitlePetra's Tech Nuke PHN Concentrated Biocide (10mL)
PackageQuantity1
PartNumberphnnuke
ProductGroupSingle Detail Page Misc
ProductTypeNameMISC_OTHER
1 - 1 of 1 Posts
