If you don't anticipate that many clients connecting simultaneously to your network, you should probably make the DHCP range smaller. Probably start from 192.168.1.100 - 200. That gives you 101 IP address to lease.
You mentioned you're trying to assign each computer an IP address, what exactly do you mean? Are you assigning a DHCP Reservation on the DHCP server? Or are you manually assigning the IP address on the client? If the former, is there a particular reason you're using DHCP reservations?
Never used the pfsense appliance, but technically there shouldn't be any "errors" for assigning DHCP reservations that's inside or outside of the DHCP scope.
With regards to the WGR614v2, you should assign a static IP address to the LAN so it doesn't change. Probably assign it on the device itself.
Moving forward - I'd probably remove the WGR614v2 from the equation first and see if you can connect directly to the pfsense with a computer and get internet working on that one client computer first. i.e. make sure DHCP works, routing is configured properly, DNS is set properly, etc.
