1 - 20 of 153 Posts
· Premium Member
Like I said on another thread - from now on gonna get my games when they are in the £5 bargain bucket !
By the time patch 1,2,3,4,5..... have all been released and my computer will then play at a staggering 600 fps.
Tired of being a test dummies for these game developers.
How many games do you know that have just been released and suffer on launch day ?
· Overclocked by Jesus
From the comments section of the article LOL
(•_•)
Give your graphics card enough ropes...
( •_•)>⌐■-■
(⌐■_■)
...and it'll hang itself...
YYEEEAAAAAAHHHHHH
Reactions: Bactine
· Premium Member
Originally Posted by White Fire View Post
Scumbag ropes lol
exactly lol!
· Jayce
· Premium Member
I have set Shadows and Shaders to High, also entered this command : r_FogShadows = Off and I got over 50% performance increase over "default" Very High settings.
My settings:
All settings to Very High except of
Shadows and Shaders = High
FXAA
Motion Blur = OFF
AF = 16x
1920 x 1080
plus my autoexec.cfg file which contains:
r_FogShadows = Off
r_TexturesStreamPoolSize = 1024
e_MergedMeshesViewDistRatio = 100
e_LodRatio = 80
e_ViewDistRatio = 150
e_ViewDistRatioVegetation = 150
e_ViewDistRatioDetail = 150
NOTICE: command "r_TexturesStreamPoolSize = 1024" increases dedicated VRAM for textures from 512 to 1024MB (at least 2GB card is recommended)
Distance Ratio is also increased from default 100 to 150.
Now I have smooth gameplay and FPS ranging between 45 and 60 FPS.
Before on "default" Very High settings my system would struggle in 30 - 40 FPS area.
HW: 2500K @ 4.5GHz
HD7950 @ 1050/1750MHz
8GB RAM @ 2133MHz CL10
CHEERS..
Not really surprised. Their method of ropes is... strange. Its definitely realistic, but as a result murders FPS.
CE3 seems to handle ropes from a base-up approach. Firstly, the ropes are made up of segments. You could really call it a "chain", just made to look like a rope. When you pull on the bottom segment, it pulls on the next, which in turn pulls on the next, etc. Unfortunately, All this pulling is updated on a frame-per-frame basis*, which is just really, really demanding on the CPU. In the end, you do get a very realistic rope-like setup. It's really pretty good. However, they could have lowered the realism a bit, and gone with a 2-point spline system, which would just rely on a passive-update system. It wouldn't look as good, or be as realistic when interacting with it, but for that application, it would be identical. The other issue murdering FPS here is that there's an object at the end of the rope. Now you've got a physics check on it, as well as the rope. Every frame the engine goes "hey this is pulling down on segment 1", and then segment one says to segment 2 "im being pulled on, and I'm also pulling on you". It adds up.
*Its frame-by-frame when IN-FRAME. Physics simulations of single objects (cloth, ropes, etc.) pause when off-camera to increase performance. Its quite hard to tell, but there IS a console command to disable this feature (enjoy 20fps EVERYWHERE in the 1st level), and you can test for this via shadows. If a light is shining on a tarp or something and casting a shadow, keep the tarp behind you, and the shadow in front of you. Once the tarp is off-frame, the shadow will stop moving, as the object casting it has stopped moving.
· Premium Member
Discussion Starter · #16 ·
That's really interesting. I never knew that.
Thanks for sharing.
Interesting.... Is there a way to disable the "rope movements" to get better framerates?
1 - 20 of 153 Posts
