1 - 18 of 18 Posts
Originally Posted by Jrice00
Does it not measure v-core?
Mine didn't either... weird.
OP: Gratz! How stable is it? I know my 940 gets finicky at anything over 3790mhz
Just curious, since, you're running a higher OC than me.
well its pretty good for now just did a few 3dmark 06 (19887)
did a occt 20min test no errors! * my temps on my cores were 43c/45c on test.
CPU-Z Validator doesn't show the core voltage.
Originally Posted by denn_is
sh** i just got a BSOD. time to rethink this one. woops... rock stable @ 3.5!
Sigh... another one stuck at 700oc
Still a nice overclock, though!
shoulda gotten a 720 BE lol. mine does 3.8 without even sweating.
nicely done!
and 3.5 stable is not that bad.
what the voltage anyway?
this sux i have some problem wit my bios.. all i can get for volts is 1.328v.
i know i could be stable a 3.6 if i had more volts.:swearing:
for some reason the highest i can see in my bios is 1.35v. :swearing:
mobo is in my sig!
mobo is in my sig!
Have you updated your bios?
You should be able to do WAY more then 1.35v
dunno. but there must be something there. honestly, i find a biostar's bios to be very complicated. but it's complete. they just added more stuff. i wish it was a bit user friendly though
good luck man!
Very nice overclocking.
3.6ghz stable requires about 1.45v on my CPU.
Make sure you're doing the stability testing with large FFTs and then do things in the background, the stability tends to fall apart under these conditions.
1 - 18 of 18 Posts
