Hey everyone! Finally finished my build, I was inspired by Sedici's post and his custom side panels sold me. I took his file and modified it a bit, adjusted it for the evolv shift x. Attached is my final mockup for the side panel, not 100% sure if I'm going to use both panels ( planning on cutting two ).Here's a link to a Google Drive folder which includes the raw .DXF file from Autodesk Fusion. Also has an .EPS file which opens using Adobe Illustrator. A lasercutter/waterjet place should be able to use the EPS file. The side panel was a couple of millimeters short for me, but not noticeable enough for me to get it remade. If anyone plans on using it, extend the top part 2-3 millimeters if you want.
The original dimensions are 471mm x 228mm.
https://drive.google.com/drive/folders/14wOqHyFzTH_esAPc8lE5fQLQ41bYE88j
I live in Silicon Valley and had one of the dozens of local shops do it lol. It cost me $60, materials+cut time. A few other CNC places that take online orders are eMachineShop, Xometry, Ponoko, and Big Blue Saw. Lasergist laser cuts, but last time I checked they only do steel. And I think they also have a size limit which won't fit a side panel. Ponoko has a lot of acrylic options.
Big Blue Saw does waterjetting, and offers instant online quotes. Here's prices from BBS for the single side panel. ~3mm thick 6061AL
^^ How is the EK-Quantum Kinetic FLT120 pump/reservoir combo? I may get one for a future compact build.Silver Glint
CPU: AMD Ryzen 7 3700X
Motherboard: Gigabyte X570 I Aorus Pro WiFi
Memory: G.Skill Trident Z Neo 3600 MHz
Storage: Intel 660P Series, 500 GB & 1 TB
Graphics: Sapphire Radeon RX 5700 XT
PSU: Corsair SF600 Platinum
Case: Phanteks Evolv Shift TG
Fans: Noctua NF-F12 (2x), NF-A14, NF-A12x15
Cooling: EKWB ZMT Tubing, Velocity Strike RGB, Vector RX 5700 +XT Special Edition, EK-Quantum Kinetic FLT120, EK CoolStream SE 120 (2x), and Fittings.
It's good. I use the DDC as it is more compact than the D5 obviously. You really need to pay attention to its overall thickness for small build.^^ How is the EK-Quantum Kinetic FLT120 pump/reservoir combo? I may get one for a future compact build.
This is interesting.. May I know what is the IDLE & AMBIENT temperature for CPU & GPU ?Silver Glint
Hello,
My config
Step 1:
i7 9700k
MSI Z390i MPG Gaming Edge AC
CORSAIR Hydro H80iV2
CORSAIR SF600
2x16Go 3200 HyperX
PNY XLR8 CS3030 1To
PNY XLR8 CS3030 500Go
Shadow Wings 2 Fans 140mm
ZOTAC RTX 2070 SUPER MINI
https://imgur.com/gallery/YHYmzLh
Step 2 :
NZXT KRAKEN G12
CORSAIR HYDRO H55
NOCTUA NF-A12x15 PWM
https://imgur.com/gallery/E1uZ7b7
Final :
Airflow :
Bottom CORSAIR Hydro H80iV2 1x120 fan + 1x120 NOCTUA NF-A12x15 PWM (push-pull) -> intake (will try exhaust later)
Top front Shadow Wings 2 1x140 -> intake
Bottom/front CORSAIR HYDRO H55 1xNOCTUA NF-A12x15 PWM -> exhaust
Currently my biggest problem is the front panel. Hot air is badly evacuated
After 1 hour gaming (without front panel)
Silver Glint
O it definitely suffers. I had a full water cooling set up in a shift X and my temps where terrible.Probably Shift X doesn't suffer as much from GPU overheating since its designed for custom cooling. Some mods I did to improve cooling and be able to use dual AIO.
cheers radu,
all plumbed up and live, pending OS install. Not quite as planned out as it could have been, turns out the pump inlet/outlet is not what I had hoped (or even considered TBH), the GPU is being feed through into the outlet...shize. I'm assuming you can't just reverse a pump impeller and this means re routing the tubing, maybe I just roll with it and see how it runs??
