https://www.newegg.com/Product/Product.aspx?Item=N82E16811854042
The above case will be delivered tomorrow.
I wanted to know what type of fan setup I should go with as the case comes with 2 and I'd want 2-3 more. I don't know what rpm they should be and if I shouldn't mix them with the fans that come with it.
I'd also like some fan recommendations and matching the same color scheme isn't that important.
This is what I was thinking of but I thought that might be too much intake. The two arrows going through black rectangles near the upper left corner represent fans on the NH D15.
Should I also take the slot covers off to help with the heat between the GPU and PSU ?
