Phanteks PH-TC14PE questions
787 Views 3 Replies 4 Participants Last post by  pooter
Hi,
Just some random questions about the Phanteks PH-TC14PE cooler: http://www.newegg.ca/Product/Product.aspx?Item=N82E16835709001
1- Is this a good cooler ? Can it replace a liquid cooler like the Corsair H100 ?
2- Will it fit inside a Define R4 case from Fractal Design ? If yes, will it prevent me from placing my RAM sticks ?
3- What 8 GB RAM do you recommend with that cooler ?
1 - 4 of 4 Posts
I've got the black model in my R4 with an i7 920 @ 4.0Ghz 85c load. Seems good. It is huge though. As for ram, be careful with how tall it is. The HS could block taller sticks. I had to put my fans in a pull configuration to allow my ram to fit.
Phanteks PH-TC14PE = 5x 8mm pipes; 140x134x160mm; 140x159x171mm w/fans; PWM adaptor included; 40-45mm bottom fin to CPU + 8mm CPU to motherboard.
My G.Skill Trident X with heatspreader fins removed fit perfect without needing to shift the fans up.
1 - 4 of 4 Posts
