Phanteks Primo Measurements Resource
FAQ Measurements
Applies to 480mm Radiators:
** For more text measurements you can also refer to the 1st post of the Phanteks Case Club FAQ here. **
Picture Measurements:
- Alphacool UT60 and XT45 Measurements in Push/Pull orientation, with 24mm and 38mm fans (bottom of case only)
- Also included some measurements and visuals of XT45 in top position of case, with/without fans.
Disclaimer: These may be off a few millimeter due to holding the tape at a very slight angle in some cases, or due to optical illusion from camera angle, but for the most part they should be useful as reference or within 1-3mm actual.
General Measurements
Alphacool XT45 480 in Top, with measurements
Another Disclaimer
the hanging drive cage that I measured up to was unsupported at the time, and naturally sags probably 2-3 mm at the very end of it, (farthest point from front) so you may have to take that into account with the measurements up to the drive cage.
Alphacool XT45 480 Radiator in Bottom Push/Pull 24mm
Alphacool XT45 480 Radiator in Bottom Push/Pull 38mm
Alphacool UT60 480 Radiator in Bottom Push/Pull 24mm
Alphacool UT60 480 Radiator in Bottom Push/Pull 38mm
I can take some other measurements right now by request, since my case is all apart and it's easy. Once I get it all assembled it may be harder/impossible
Enjoy
FAQ Measurements
- Bottom Radiator clearance between 5.25" OD side panel and PSU shroud = 126-127mm (see pics in general)
- Top Radiator clearance between OD drive sides = 145mm
** Phanteks released a Revised reservoir bracket to accommodate dual GPU configurations easier and without modification to the bracket. This change happened sometime in Q4 2015.Originally Posted by Phanteks Team
Even with the revised bracket** the clearance won't fit a GPU larger than 257mm with cover.
Clearance
Graphic card
257mm (reservoir bracket installed)
277mm (reservoir bracket installed w/o cover)
350mm (no reservoir bracket)
390mm (HDD cages in front position)
515mm (no HDD cages)
Another Disclaimer
