Im on a b550 carbon. I have 7 fan ports and i can safely run at least 2 fans per port.I'd never recommend a corsair commander . There's joking and then there's recommending Corsair. I would recommend the aquaero if you can afford it or a Quadro if you can't, though it does really depend on how many fans you're running. Just a handful and I understand not wanting to spend extra.
I think MSI might have the best BIOS fan control, and it's just OK.
Al others vary from meh, to "OH!, HELL NO!!!".
Before the b550 carbon i went for a b550 strix F (literally same tier of board). Compared to the MSI, it was PAIN.
---Couldn't run fans lower than 40%, before they stopped. Personally, I'm running bellow that under most loads....
On MSI i can run sw3 120 high speed at 250rpm. That's close to 10%.
--- the carbon has 1 CPU, 5 sys_fan, 1 pump. The strix F, had 1 CPU, 1 CPU opt (it wouldn't even appear in the bios), 1 pump and 3 chasis fan. Funny part is, FANCONTROL would see and let me control the CPU opt fan port.
Tbh a CPU opt fan port nowdays it's just plain dumb..... you can run 2-3 fans on one port safely.....
---Horrible placements......for the fan ports and others too..... and that layout is not new nor unique nor on a handfull of Asus boards.....
Had more issues with that board regarding cooling but i don't remember.....
Srry for the rant, but i just had to take it of my chest.....
Tbh it would still pain me to pay 140€ for and aquero even for a loop, if I'm not running more than 1 pump and a few probes.....
I'm not much of fan of hubs either, because you lose flexibility compared to individual fan ports. So using the motherboard is better for more than 1 reason, but the control it's just bad on most.
Big fan of the Fancontrol thingy by remo0. Been using it for past 2 years....
