Ok all, I have been waiting a while: doing my research, planning, waiting for prices to come down (they haven't really), and waiting until i had the money and wife's permission. I am building my dream PC. I have built many PCs in the past but this will be my first time watercooling and heavily overclocking (I've OC'd a tiny bit). Anyway, Here is the pcpartpicker link to my build with all of my intended parts:
https://pcpartpicker.com/user/iRon_Man22/saved/#view=JDxJ7P
Basically, I am looking for all of the opinions, critiques, suggestions on my build. I am including a picture (hand drawn so be kind) of my tube routing design. Ignore the colors, I did those just to help distinguish parts from one another. My questions that I am looking for answers:
1) Do you see any problems with my design?
2) Do you think I will have room to add another 240 rad in push/pull config. behind the dual tube reservoirs? I calculated the with of the reservoirs, rad, and fans compared to the width of the case and I should have enough room. Tell me if I'm wrong.
3) Do you see any improvements that I should make?
4) I want to plan for easy filling and draining of my system, that is why I am including a bay res. Is this the best way to plan for a draining/filling system? How can I plan this better?
Please also keep in mind a few notes about my drawing/design:
1) I am planing to mod my Primo case by cutting out the rectangular section where my two tube reservoirs are going so they show. Here is an example of what I mean.
2) I plan on having two D5 pumps on this system, one in the bay res and one on the pump mount the case provides in the back.
3) My flow pattern: Bay Res -> CPU -> 480 Rad -> GPU1 -> GPU2 -> 240 Rad -> Tube Res 1 -> D5 Pump -> 240 Rad 2 -> Tube Res 2 -> Bay Res ---Is this well planned? Any changes?
4) My color theme is going to be Black and Blue.
Let me know if you have any questions, thank you for taking the time to read this through!
