Originally Posted by blob I know... thats like adding a Mach II section, and only one person would be in it. |
Originally Posted by YiffyGriffy For the 2 whole people on this forum that have phase change systems? ![]() |
Originally Posted by YiffyGriffy Yeah, that's assuming you don't impload your computer or blow your arms off ![]() I'd kinda like to build my own system...but I get this feeling that it still wouldn't be much cheaper than buying one... |
Originally Posted by Lando95 LOL, yeah the compressors used are usually out of air conditioners or dehumidifiers. Usually around 1/4 to 1/2 horsepower or so. You can usually find used ones for pretty cheap. It's all the tools/gases/labor that become expensive. If you know what you are doing, you can build one for FAR cheaper than a new Prommie. |
Originally Posted by Kittani Dudes... just buy a compressor like they use for nail guns and stuff.... all you'd need to do is put a tip on the end that is tiny and turn it to full blast... I know my compressor can cause frost on a glass and if I leave it in one spot long enough it will start to freeze the water. |
