Is the 1600mhz HT just a recent phenomenon? Or do you think its been that way the whole time?
it's a known glitch that biostar boards can't set an 1600mhz or higher ht speed on the 940's (and i think deneb's in general) for some reason.
what you can do is just overclock the system to get the higher ht speed. |
Please try not to double post. You already have the same post up in AMD CPU section. Someone already has written a answer. I think the above solution might do it.
Also try a Bios update and see if that fixes the problem, and by overclock he means raise the NB frequency. It should raise the HT as well
(HTT Multi) X (FSB or HTT) = HT Link speed.
Raise the multi if your BIOS allows it
