Hi. I just picked up a computer with a Phenom 9600 BE in it so i was excited to see what it would do...turns out it does nothing..
Here's the specs:
AMD Phenom 9600 Black Edition (2.3 Ghz/1800 HT)
Foxconn A7GM-S 2.0
780G Chipset
4 GB 1066 GSkill Ram in unganged/dual channel
680 watt power supply, not sure the brand at the moment.. will look if needed.
Here's what I've tried. I was just trying to go to 2500 by increasing the multiplier to 12.5x, but it would freeze or BSOD in windows everytime i did. So i bumped the voltage by 150 mv... no change... so i thought i would just go for an end goal and set it to 13x and put it at 200 mv.. didnt even get to the windows loading.. so i went to 250 mv, got loading screen with lock-up.. at 300 mv, it started loading and then BSOD... I also tried to oc the HT/NB with no success. It runs 1800 mhz stock so i went 2000 on both with a 60mv increase on both... no luck... any ideas on why i can't overclock anything?
Here's the specs:
Foxconn A7GM-S 2.0
780G Chipset
