Originally Posted by Contagion
Make sure enable a feature called either of these
ACC
Unleashing
Hybrid
Set the voltage to 1.2 and work up from there.
On my chip (550 BE) I got 3.5ghz stable on stock volts (1.35v)
I did follow all the steps, and it does not work. I think it might be something conflict with operation system since I was able to unlock it with XP pro. Well, I like Windows 7 better than XP pro, so I don't mind to get 2 extra cores. About the overclock, I am new on AM3, so I didn't know how to adjust the memory. I am using
Mushkin blackline. When I set fsb to 250, ddr3 1600 vdim 1.85V, vcore 1.4V, memory will be 1667 8-8-8-20. Then I run prime95 around 1 hours, the computer will get blue screen dump memory. I even lower ddr3 to 1300 8-8-8-20, the system will get blue screen dump memory after 2-3 hours burning prime95. What should I do next?
