1 - 14 of 14 Posts
If you bought it retail I'm sure it will. AMD generally gives out decent heatsinnks. Of course aftermarket will be better...(Like a Ziggy Dark night?)
· STG3 VET
It should come with a heat sink. It is sufficient to cool your cpu.It is not is not recommend to overclock with it.
If you pan to overclock get a
Thermalright True
or
Noctua
or
Xigmateck Dark Knight
· Efficiencycionado
yeah. but it's the one without the heatpipes. don't worry, those new phenom chips run very cool that you can oc them with stock voltages.
· Efficiencycionado
· Premium Member
· Efficiencycionado
just max the fan when you're ocing.
that cooler will be fine. it looks very similar with ac64. but i don't think it will cool well with high oc temps.
when you have a money, buy a true it's the best for amd. xigmatek dark night is a cheaper solution.
http://www.frostytech.com/top5heatsinks.cfm
· Efficiencycionado
cheers
· Premium Member
Discussion Starter · #11 ·
Whoops, a couple more questions.
Will an AM2 heatsink clip on to an AM2+ board ?
I was looking at the Scythye Katana 2, but it´s only listed as AM2.
It´s going for 22 euros, I can squeeze that in, if you guys think it´s worth it.
http://www.frostytech.com/articlevie...articleID=2126
· Banned
Yes, the clipping mechanism is universally compatible with 939 / AM2 / AM2+ / AM3.
1 - 14 of 14 Posts
