Phenom II 720BE or the Athlon II 630
5570 Views 72 Replies 24 Participants Last post by  Pentium4 531 overclocker
alright... i have a pick at a new CPU... i cant buy online so dont start belting me with price adjustments......or start belting me on more expensive CPU's cuz im on a budget....
first up.... the
AMD Phenom II x3 720 Black Edition @ 2.8GHz 6MB cache with unlocked multiplier @ $129.99 CAD
VS
AMD Athlon II x4 630 @ 2.8GHz 2MB cache with locked multiplier $129.99CAD
@ $124.99 CAD
AMD Athlon II x4 620 @ 2.6GHz 2MB cache with locked multiplier $112.99CAD
VS
AMD Phenom II x4 925 @ 2.8GHz 8MB cache wit locked multiplier $155.99 CAD
if anyone has other suggestions @ $170.00 and under plez let me know and i will see if its in stock. if not then
******************(long swearing)*********!!!!!!
the websites that you guys can pick from are
www.tigerdirect.ca
www.canadacomputers.com
do not bull **** me with newegg.... i could have bought from there but theres an issue with the credit card right now...
edit
i decided to pop in the Athlon x4 620 cuz mabey i can save a bit there? $112.99
1 - 20 of 73 Posts
The rest of these benchmarks can be found here: http://www.anandtech.com/printarticle.aspx?i=3638
As you can tell the 630 actually beats the tri core 720 due to its extra core.
However in games the 720 really shines out as the faster chip. Either way, both chips are good, but if you have a budget in mind, the 630 is the way to go
However, one edge the 720 has over the 630 is its overclocking ability. Most owners can raise the cpu speed past 3.6ghz. With the 630, the testers couldn't even make it to 3.4ghz
i have the 720 to.its been good to me and im a gamer.i was lucky to be able to unlock it to.i think its one of amd's best cpu's out there.and the price is great
Originally Posted by neDav
The 720 gets my vote. The only other option I couls think of is the 550 BE.
http://www.tigerdirect.ca/applicatio...457&CatId=4431
must have been a price hike on the 550
I found a good CPU for you. Its and AMD Phenom II x4 quad core 3.0GHz w/cooling fan and a 3-year warranty. Here it is:
http://www.mwave.com/mwave/skusearch...iteria=AA76360
looks nice... but i have supplied 2 websites for you guys to pick from... and the price you found is way below what my sites are putting up.. i had those sites because they the ony stores withing my area...
looks nice... but i have supplied 2 websites for you guys to pick from... and the price you found is way below what my sites are putting up.. i had those sites because they the only stores withing my area...
woops sorry for the double post.... and the voting is at
ATHLON II: 3
PHENOM II: 2
(my friend put his bet on the athlon II)
This is a no-brainer, with the price difference of $47 CAD, I hope nobody pick the 720 over the 630. With the $47 you save, put it toward to a GPU you'll buy in the future.
looks ok.... i might be able to unlock some cores... just the only thing that i have in mind is EWWW dual cores!!!!!
The 720 will outdo the 630 in games, especially if you can unlock the 4th core, but for $47 you should get the 630 and get a nice gpu. Just my
im guessing its
Athlon II:6
Phenom II: 2
because i plan on a new GPU anyways.... or a nice old crossfire...
hrm.... second though.... mabey i add the Athlon II x4 620? i mean they the same thing except for stock speed right? and the whole point of this is to start ripping on overclocks. (the website) so why not? add the Athlon 2 x4 620? 3 way voting people!!!!
The scores
Athlon 2 630:6
Athlon 2 620:0
Phenom 2 720:3
looks like phenom 2 is making a come back!!!
1 - 20 of 73 Posts
