Mostly likely the ill effects of the stock heatsink. With any 120mm heatsink you won't be breaking 40c. But while you have the stock one you shouldn't OC it much, as you don't want to break 60c very often.
Cooler master hyper 212 plus, one of the best heat sinks for rediculously cheap.Originally Posted by kiwiasian;13080260
But it's normal for a stock heatsink, right?
Any recommendations for a cheap (cheap) heatsink that'll give more manageable temps?
