You should just keep it at stock because you probably wouldnt be able to gain too much performance for the heat gain. Just save up and buy a better cooler.
Originally Posted by Bleached ![]() I have read some people going to about 3.5Ghz (250 ref. clock) on stock. That is a pretty good overclock. I wouldn't suggest higher as you can damage your system overtime. The best overclock for a 920 can be found here: http://www.overclock.net/amd-cpus/44...-database.html Try for a 3.4Ghz; that would be pretty safe and won't get extremely hot. You won't really see a huge benefit unless you are looking to get a new gpu as well. Good luck and have fun. |
