The temp sensor on some of the 940's is kind of FUBAR.
What are you using to check temps?
Originally Posted by Conley ![]() The temp sensor on some of the 940's is kind of FUBAR. What are you using to check temps? |
Originally Posted by PC Gamer ![]() Yeah, with the stock heatsink, I'm currently getting 30c. Mabye you should try reseating the heatsink. |
Originally Posted by pez ![]() Unless you have cool'n'quiet on, there's no way you have 30C on a stock cooler. Unless you're ambients are around 15C... |
Originally Posted by pez ![]() That's true. If I enabled some type of CnQ with my P180, I would manage 29C. With my Sniper, which is a ton better at airflow, I'm sure I'd hit somewhere around 25C idle. |
Originally Posted by its my first time ![]() I used the dab method, but didn't twist the heatsink (eve though it says to in the heatsink instructions ![]() I might clean heatsink and cpu and re apply compound. |
