1 - 16 of 16 Posts
Someone can help me for the voltage on my M4A79 ?
Originally Posted by dieanotherday
TWKR, wow, lucky
If you can get your hands on a true TWKR you would not have to ask this....i call unlocked CPU or BS
VeeDub Enthusiast
agreed!
Originally Posted by dreadlord369
Isn't the twkr supposed to run on dice and ln2 systems exclusively? Or am I wrong?
There expensive high binned CPU's so they are usually only seen on dice or ln2...they will run on air but enthusiasts just run them on the best to push the most out of them
It can run on air, but it was designed with extreme benching in mind.
they where designed for greater voltage leakage which gives then the ability to clock higher with less voltage
Wait Wat?
So they are actually specially designed for it...and not highly binned then
Neat
Neat
Would be if he had a clue what he just said
Originally Posted by lockdownx1x
Wait Wat?
Quoting this link http://cgi.ebay.com/ws/eBayISAPI.dll...=263602_263622
These chips were created especially for the extreme overclocking community to operate beyond the specification of typical production-level processors. What makes these chips special is the fact that they are considered “high leakage†parts. In this context, high leakage means that the processors "leak" more current than a normal Phenom II CPU and consequently run hotter, which actually turns out to be a positive for the overclocking crowd (even if it means they're more likely to die an early death). They can take on more voltage and generally tend to scale higher when cooled with extreme methods, such as liquid nitrogen or liquid helium.
from your quote
Not they can clock higher with less voltage.
To put it in layman's terms. These chip just have a much better tolerance for high voltages than the regular retail samples.
1 - 16 of 16 Posts
