1 - 5 of 5 Posts
My stock Vcore is 1.33V, is this normal? It seems high to me for a stock setting.
Im running an ASUS CM1630 Phenom II x4 835 with a HD 6750, Thermaltake 650W, other than that is stock. Is this normal?
Discussion Starter · #2 ·
If this is normal does that mean I can OC my OEM CPU a little without any problems?
Normal Stock voltage is aroung 1.35v. I wouldn't try to oc on this rig. The stock ram, stock cooler and mobo is not design to be oc on.
Your motherboard is probably based on the M4A78LT-M (as in, not the LE version), which has a quality 4+1 phase board ready for overclocking with VRM cooling (stock CPU fan counting as VRM cooling, of course). Could try it with AMD overdrive if you can't get BIOS access, by pressing ctrl + F1 to try and unlock or something.
Awesome, thanks guys for the advice. Off subject I just bought a HD 7750 to replace my cousins HD 6750. Whats the best way to go about the switch?
1 - 5 of 5 Posts
