1 - 18 of 18 Posts
Read Only
I saw one of these at my local PC shop today. Is it worth buying it? Does it affect the actual CPU if the top is scratched?
My scratched, I mean that this thing has been massacred. It looks like some animal clawed at it at least 30 times, but I don't think it was an animal. The cuts are only like 1.5mm deep though. The pins are still in good shape.
If it works I would buy it and just lap it smooth with sandpaper. Can you test it?
If the shop will guarantee that it will work then yes, it is worth it.
But do expect to spend some time lapping it to make it flat again.
Read Only
The store has a 7 day return policy if I return it in the original condition. I have an AM3 MB, so I could test it I guess.
Doesn't sandpapering it just ruin it even more?
Some people do it.
It's called lapping and I believe you have to keep using higher and higher grit paper till it has a mirror finish.
Lapping the Processor + heat sink will get rid of the small grooves and convex/concave of the processor + HS
Will lower your temps
No you just start at a low grit and move your way up to a higher grit for a mirror like finish. There are a few guides on here how to lap a processor. I would first test it and run Prime95+Intel Burn test for a long time to make sure it works correctly.
Wonder if they had the stock heatsink stick to the cpu and used a screwdriver or something to pry it off?
So long as the pins aren't bent it should work fine. I ripped a 3600+ brisbane out of the socket and it worked fine.
I even bent the pins, tried to straighten them with a screwdriver & knife then finally got it back in the socket when someone told me about the 5mm mech pencil trick.
It worked fine
Bowser Has Ryzen!!
Arent those IHS's removable? Maybe replace it with another cpu's IHS, if it works great then track down another IHS to replace it.
OCN
I had my old opty naked in my lanparty board years ago, scared the pewps outta me when I was doing it =)
I'd snag it, make sure it works, and if its really hurting your contact with the heatsink, then lap her down some.
god loves ugly
I think AMD has started soldering them on. I bought a cheap-o $20 AM3 Athlon II 5000+ or something and it was soldered
Lap 1.5mm
Rather you than me
. I think the IHS is only a couple of mil deep anyway.
If you know somebody with a linisher, I would do that first, then finish off with various grits of wet & dry paper.
Bowser Has Ryzen!!
AH, wasnt sure. Havent tried ripping off any lately.
Aint da way it used to be
Originally Posted by crunchie;13057271
Lap 1.5mm
Rather you than me
Yeah, that's a lot. Probably the best thing to do would just take off the high spots and let your thermal grease fill in the gaps.
lapp it till its mirror finish. IF u lap through the ihs uve gone too far hahahaha .... But seriously if u go all the way through the ihs sand the corners down and run her naked should give u some beastly temps
1 - 18 of 18 Posts
