OK... I am new to overclocking a X940 cpu. I am just trying to get 3.6ghz out of it. Nothing real serious. I am having some trouble finding the proper info regarding temps and voltages. I have the multiplier set to 18x now. Voltage is set at 1.40. Every temp software uses different terminology so it's a bit confusing. Speedfan reports core temp at 58C at load and voltage at 1.52. Core temp reports same temp but calls it CPU temp. Hardware monitor reports same temp as well but shows it 4 times as independent cores. From what I have read these temps are ok since under 62C. Just wanted some insight from guys that no more than me on this subject. By the way, what is the TMPIN0, TMPIN1, and TMPIN2 temps reading in hardware monitor? They are showing 36C, 39C, 42C at idle as I type.
