1 - 20 of 50 Posts
4K HDR 60hz 4:4:4 is not that common even today.
How so? There are many TVs that can do the specs you're rating. Unless we're talking full 10-bit HDR and not 8bit HDR.
User
Exactly it's not possible under HDMI 2.0 because HDR uses 10 bit,some TV's even do their processing at 12 bit. HDR can't go over 4:2:2 and DP 1.2 does not support HDR
I've never heard of a 4K monitor that cannot do 4K RGB Full at 60 Hz (which is basically 4:4:4).
HDR works fine on DP 1.2.
Discussion Starter #9
Yes HDR is supposed to be 10 bit from the go.
HDTV can use 4:2:2 8bit 4K60 HDR over HDMI2.0
This monitor can do 4:4:4 10bit 4K60 HDR if i am not wrong since it is HDR1000 certified?
There's enough bandwidth for full HDR 4:4:4 at 4K60? If so, that's great news. Makes you wonder why TVs today didn't have it if this monitor can pull those specs with HDMI 2.0, unless this is all over DP.
It's a bit sad that they made such a feature-rich display with improved VA response times while skimping on backlight uniformity.
PC Evangelist
Nope.
HDMI 2.0 cand do: 4K 4:4:4 SDR 8-bit, 4K 4:2:2 HDR 10-bit, 4K 4:2:0 HDR 12-bit. Chroma subsampling only matters for text in Windows. If you play a game or watch a movie there is no needs for 4:4:4.
It's on Amazon for preorder and I bought one to compare to my NU8000 which is basically the TV equivalent. I can only get the NU8000 down to 42hz Freesync range so hopefully better luck with the Phillips.
I would buy a x27 but just can't use anything under 40 anymore after using 40+ TV's monitors for so long and feel it's a waste of time in such a small format.
Robotic Chemist
HDR works fine at 4K 8-bit RGB 60 Hz. You need 10-bit encodes for HDR but the GPU dithering from 10-bit to 8-bit for display is fine.
Discussion Starter #17
I think the GPU having to dither down to 8bit for HDMI2.0 output is bad, HDR content definitely needs 10bit to avoid banding.
While a monitor using FRC to dither to 10bit is less bad.
That is said, anyone confirm this monitor, DP1.2a, can do HDR 10bit, 4K60 4:4:4?
Robotic Chemist
Banding is not an issue with dithering, you get a raised noise floor but not banding.
Review is up with measurements:
https://be.hardware.info/reviews/8363/philips-momentum-436m6vbpab-review-blik-in-de-toekomst
Uniformity is horrific but on the flip side it's one of if not the fastest VA in terms of pixel response. Really wish it was FALD but either way it's a nice stop gap until the 4K 144hz FALD stuff not only becomes available in this size but is introduced at a reasonable price over the next couple years.
EDIT: You can clearly see vertical bands/DSE on their windows display settings sample image. If this is another panel lottery in that regard I'm only going to play once.
Discussion Starter #20
I wonder if the text fringing and vertical bands from 2 reviews are because this monitor DP1.2a cannot do full 4:4:4 chroma over 4K60 HDR?
No mention as yet, meh!
1 - 20 of 50 Posts
