1 - 5 of 5 Posts
Hi, I'm trying to find an update for the BIOS settings on my not worth overclocking PC.<br>
An old eMachines700dvd, it used to try and run on ME but I've recently upgraded to XP Pro.<br>
It's not for doing anything fancy, just the odd surf - I run a Mac so this is purely for fun<img alt="" class="inlineimg" src="/images/smilies/rolleyes.gif" style="border:0px solid;" title="Roll Eyes (Sarcastic)"><br>
I also tried to add a 2nd dvd drive but I messed that up.<br>
If anyone can spare the time I'd be very grateful<br>
Hope the info I've provided is what's needed. Sorry if it's too much<br>
Ciao<img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb"><br><br>
BIOS Date: 07/05/00<br>
BIOS Type: PhoenixBIOS 4.0 Release 6.0<br>
BIOS ID: 31511.EM.0000.D.0007052014<br>
OEM Sign-On: None<br>
Chipset: Intel Whitney 82810 rev 3<br>
Superio: ITE 8702F rev 4 found at port 2Eh<br>
OS: WinXP SP2<br>
CPU: Celeron(TM) 700 Mhz<br>
BIOS ROM In Socket: No<br>
BIOS ROM Size: 256K<br>
Memory Installed: 384 MB<br>
Memory Maximum: 512 MB<br>
Memory Slot 01: 128 MB<br>
Memory Slot 02: 256 MB<br>
ACPI Revision: 1.0<br><br>
Number of CPUs1<br>
NameIntel Celeron<br>
Code nameCoppermine<br>
SpecificationIntel Celeron 700 MHz<br>
Family/Model/Stepping683<br>
Extended Family/Model0/0<br>
Brand ID1<br>
PackageSocket 370 FC-PGA<br>
Core SteppingcB0<br>
Technology0.18µ<br>
Instructions SetsMMX, SSE<br>
Clock Speed697.9 MHz<br>
Clock multiplierx10.5<br>
Front Side Bus Frequency66.5 MHz<br>
Bus Speed66.5 MHz<br>
L1 Data Cache16 KBytes, 4-way set associative, 32 Bytes line size<br>
L1 Instruction Cache16 KBytes, 4-way set associative, 32 Bytes line size<br>
L2 Cache128 KBytes, 4-way set associative, 32 Bytes line size<br>
L2 Latency2<br>
L2 Speed697.9 MHz (Full)<br>
L2 LocationOn Chip<br>
L2 ECC Checkenabled<br>
L2 Data Prefetch Logicno<br>
L2 Bus Width256 bits<br><br>
eaxebxecxedx<br>
Function 0000000000000002756e65476c65746e49656e69<br>
Function 000000010000068300000001000000000383f9ff<br>
Function 000000020302010100000000000000000c040841<br><br>
edxeax<br>
MSR 0000002A00000000CFC00000<br>
MSR 000000177F33000000000000<br>
MSR 0000011E00000000007405E5<br>
MSR 0000008B0000001400000000<br><br><br>
Chipset<br>
------------------------------------------------------------------------------<br><br>
NorthbridgeIntel i810 rev. A3<br>
SouthbridgeIntel 82801AA (ICH) rev. 2<br>
Memory TypeSDRAM<br>
Memory Size384 MBytes<br>
CAS#3.0<br>
RAS# to CAS#2<br>
RAS# Precharge2<br>
Cycle Time (tRAS)5<br>
Bank Cycle Time (tRC)7<br><br><br>
Memory SPD<br>
No SPD information available<br><br><br>
Monitoring<br>
Sensor ChipIT 0<br><br><br>
PCI Device List<br>
CPU to PCI Bridge<br>
vendor ID0x8086 (Intel)<br>
device ID0x7120<br>
revision0x0003<br>
sub vendor ID0x109F (unknown)<br>
sub device ID0x3151<br>
class code0x06<br>
sub class code0x00<br>
bus 0, device 0, function 0<br><br>
Register configuration<br>
0 1 2 3 4 5 6 7 8 9 A B C D E F<br>
00 86 80 20 71 06 01 80 20 03 00 00 06 00 00 00 00<br>
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
20 00 00 00 00 00 00 00 00 00 00 00 00 9F 10 51 31<br>
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
50 68 71 FC 2B 00 00 00 00 00 00 00 00 00 00 00 00<br>
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
70 CE 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
80 06 F8 1F 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
90 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
F0 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00<br><br><br>
VGA display controller<br>
device ID0x7121<br>
revision0x0003<br>
sub vendor ID0x8086 (Intel)<br>
sub device ID0x7121<br>
class code0x03<br>
bus 0, device 1, function 0<br><br>
00 86 80 21 71 07 00 B0 02 03 00 00 03 00 00 00 00<br>
10 08 00 00 F8 00 00 00 F4 00 00 00 00 00 00 00 00<br>
20 00 00 00 00 00 00 00 00 00 00 00 00 86 80 21 71<br>
30 00 00 00 00 DC 00 00 00 00 00 00 00 0B 01 00 00<br>
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 21 00<br>
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br><br><br>
PCI to PCI Bridge<br>
device ID0x2418<br>
revision0x0002<br>
sub vendor ID0x0000 (unknown)<br>
sub device ID0x0000<br>
class code0x06<br>
sub class code0x04<br>
bus 0, device 1E, function 0<br><br>
00 86 80 18 24 07 01 80 00 02 00 04 06 00 00 01 00<br>
10 00 00 00 00 00 00 00 00 00 01 01 20 30 30 80 22<br>
20 10 F4 70 F4 F0 FF 00 00 00 00 00 00 00 00 00 00<br>
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00<br>
40 00 28 20 20 00 00 00 00 00 00 00 00 00 00 00 00<br>
50 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
70 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
A0 10 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
F0 00 00 00 00 00 00 00 00 3A 04 00 00 00 00 00 00<br><br><br>
PCI to ISA Bridge<br>
device ID0x2410<br>
revision0x0002<br>
class code0x06<br>
sub class code0x01<br>
bus 0, device 1F, function 0<br><br>
00 86 80 10 24 0F 00 80 02 02 00 01 06 00 00 80 00<br>
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
40 01 10 00 00 10 00 00 00 00 00 00 00 00 00 00 00<br>
50 00 00 00 00 00 00 00 00 81 11 00 00 10 00 00 00<br>
60 09 0A 80 09 D0 00 00 00 00 00 00 00 00 00 00 00<br>
90 FF FC 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
A0 00 02 00 00 01 00 00 00 00 00 00 00 00 00 00 00<br>
C0 00 00 00 00 00 FE 00 00 00 00 00 00 00 00 00 00<br>
D0 02 20 00 00 02 0F 00 00 04 00 00 00 00 00 00 00<br>
E0 10 00 00 80 00 00 01 00 33 22 11 00 00 40 00 00<br>
F0 00 00 40 01 00 00 00 00 3A 04 00 00 00 00 00 00<br><br><br>
IDE Disk controller<br>
device ID0x2411<br>
revision0x0002<br>
sub device ID0x2411<br>
class code0x01<br>
bus 0, device 1F, function 1<br><br>
00 86 80 11 24 05 00 80 02 02 80 01 01 00 00 00 00<br>
20 01 18 00 00 00 00 00 00 00 00 00 00 86 80 11 24<br>
40 07 E3 03 E3 00 00 00 00 05 00 02 02 00 00 00 00<br>
50 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00<br>
USB bus controller<br>
device ID0x2412<br>
revision0x0002<br>
sub device ID0x2412<br>
class code0x0C<br>
sub class code0x03<br>
bus 0, device 1F, function 2<br><br>
00 86 80 12 24 05 00 80 02 02 00 03 0C 00 00 00 00<br>
20 21 18 00 00 00 00 00 00 00 00 00 00 86 80 12 24<br>
30 00 00 00 00 00 00 00 00 00 00 00 00 09 04 00 00<br>
60 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
C0 00 2F 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
Audio controller<br>
device ID0x2415<br>
revision0x0002<br>
class code0x04<br>
bus 0, device 1F, function 5<br><br>
00 86 80 15 24 05 00 80 02 02 00 01 04 00 00 00 00<br>
10 01 20 00 00 41 18 00 00 00 00 00 00 00 00 00 00<br>
30 00 00 00 00 00 00 00 00 00 00 00 00 0A 02 00 00<br>
Ethernet network controller<br>
vendor ID0x10EC (Realtek)<br>
device ID0x8139<br>
revision0x0010<br>
sub vendor ID0x1429 (unknown)<br>
sub device ID0xD010<br>
class code0x02<br>
bus 1, device D, function 0<br><br>
00 EC 10 39 81 05 01 90 02 10 00 00 02 00 40 00 00<br>
10 01 FF 00 00 00 FF BF FE 00 00 00 00 00 00 00 00<br>
20 00 00 00 00 00 00 00 00 00 00 00 00 29 14 10 D0<br>
30 00 00 00 00 50 00 00 00 00 00 00 00 0A 01 20 40<br>
50 01 00 02 76 00 01 00 00 00 00 00 00 00 00 00 00<br>
Communication device<br>
device ID0x1040<br>
revision0x0000<br>
sub device ID0x1000<br>
class code0x07<br>
sub class code0x80<br>
bus 1, device E, function 0<br><br>
00 86 80 40 10 17 03 90 02 00 00 80 07 08 40 00 00<br>
10 00 00 40 FE 00 00 00 00 00 00 00 00 00 00 00 00<br>
20 00 00 00 00 00 00 00 00 00 00 00 00 86 80 00 10<br>
30 00 00 00 00 E0 00 00 00 00 00 00 00 09 01 00 00<br>
40 80 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00<br>
E0 01 00 C2 E5 00 00 00 00 00 00 00 00 00 00 00 00<br>
DMI<br>
DMI BIOS<br>
--------<br>
BIOS #1<br>
vendorPhoenix Technologies LTD<br>
versionVersion 1.01<br>
date07/05/2000<br><br><br>
DMI System Information<br>
System #1<br>
manufacturerTriGem Computer, Inc.<br>
productEmachines<br>
version100<br>
serial0000000000<br>
UUID00000000-00000000-00000000-00000000<br><br><br>
DMI Baseboard<br>
-------------<br>
Baseboard #1<br>
vendorTriGem Computer, Inc.<br>
modelTriGem System Board<br>
revision000000<br>
serial000000000000000000<br><br><br>
DMI System Enclosure<br>
System enclosure #1<br>
chassis typeDesktop<br>
chassis serialNone<br><br><br>
DMI Processor<br>
-------------<br>
CPU #1<br>
manufacturerGenuineIntel<br>
modelCeleron(TM)<br>
clock speed700.0MHz<br>
FSB speed66.0MHz<br>
multiplier10.5x<br><br><br>
DMI Memory Controller<br>
Memory Controller #1<br>
correctionunknown<br>
Max module size512MBytes<br><br><br>
DMI Memory Module<br>
Memory Module #1<br>
designationCN3<br>
size128MBytes (double bank)<br>
Memory Module #2<br>
designationCN4<br>
size256MBytes (double bank)<br><br><br>
DMI Port Connector<br>
Port #1<br>
designationCN24 (internal)<br>
designationCOM 1 (external)<br>
port typeSerial Port 16550A<br>
connector9 Pin Dual Inline (pin 10 cut)<br>
connectorDB-9 male<br>
Port #2<br>
designationCN25 (internal)<br>
designationCOM 2 (external)<br>
Port #3<br>
designationCN26 (internal)<br>
designationParallel (external)<br>
port typeParallel Port ECP/EPP<br>
connector25 Pin Dual Inline (pin 26 cut)<br>
connectorDB-25 female<br>
Port #4<br>
designationCN29-Bottom (internal)<br>
designationPS/2 Keyboard (external)<br>
port typeKeyboard Port<br>
connectorCircular DIN-8 female<br>
Port #5<br>
designationCN29-Top (internal)<br>
designationPS/2 Mouse (external)<br>
port typeMouse Port<br>
Port #6<br>
designationCN27 (internal)<br>
designationUSB (external)<br>
port typeUSB<br>
connectorAccess Bus (USB)<br>
Port #7<br>
designationCN9 (internal)<br>
designationFDD (external)<br>
port typePC-98<br>
connectorOn Board Floppy<br>
Port #8<br>
designationCN10 (internal)<br>
designationPrimary IDE (external)<br>
port typePC-98<br>
connectorOn Board IDE<br>
Port #9<br>
designationCN11 (internal)<br>
designationSecondary IDE (external)<br>
port typePC-98<br>
Port #10<br>
designationCN31 (internal)<br>
designationVideo (external)<br>
port typeVideo Port<br>
connectorDB-15 female<br>
Port #11<br>
designationAudio (external)<br>
port typeAudio Port<br>
connectorDB-15 female<br><br><br>
DMI Extension Slot<br>
Slot #1<br>
designationPCI Slot1 - CN12<br>
typePCI<br>
width32 bits<br>
populatedno<br>
Slot #2<br>
designationPCI Slot2 - CN13<br>
typePCI<br>
width32 bits<br>
populatedno<br>
Slot #3<br>
designationPCI Slot3 - CN14<br>
typePCI<br>
width32 bits<br>
populatedno<br><br><br>
DMI Physical Memory Array<br>
Physical Memory Array #1<br>
locationMotherboard<br>
usageSystem Memory<br>
correctionNone<br>
max capacity512MBytes<br>
max# of devices2<br><br><br>
DMI Memory Device<br>
Memory Device #1<br>
designationM1<br>
formatDIMM<br>
typeDRAM<br>
total width32bits<br>
data width32bits<br>
size128MBytes<br>
Memory Device #2<br>
designationM2<br>
formatDIMM<br>
typeDRAM<br>
size256MBytes<br><br><br>
Software<br>
Windows VersionMicrosoft Windows XP Professional Service Pack 2 (Build 2600)<br>
DirectX Version9.0c
Wow that was quick!<br>
Yep tried emachines but my model is no longer supported by Support.<br>
Service means everything obviously ;o)<br>
Also tried Phoenix Technologies, no joy there either.<br>
The PC may run fine without an update, but if I can find one as Homer says "Whoohooo"!!
Discussion Starter #5
Actually No, the thing seems to be running well kind of OK. I'm kind new to this kind of thing and after googling here and there most "advice" seemed to be update your BIOS settings before upgrading to XP. Off course I didin't find that info till after I'd updated <img alt="" class="inlineimg" src="/images/smilies/redface.gif" style="border:0px solid;" title="Embarrassment">) But like swimming it's always more fun in the Deep End.<br>
By the way once I found this site I read your "How To's", fantastic! Don't have a clue what I've actually done to my PC but it was great fun
1 - 5 of 5 Posts
