OK, so I've been using this program for quite a while now. 3 years really, and over the last year I have been following all sorts of tutorials and reading about it. So by now Im confident with most tools there and have used them enough be able to let my creativity loose.
I do have 2 questions though.
1:
Effects layers (Outer glow etc) blending modes. So I understand the bending modes, that's not the issue. Say I have created a transparent image and the outer glow for example, fades into this transparency. With certain blend modes they will interact differently depending on the colour underneath. But only within PS. If the outer glow were set to Overlay. If the under layer was set to a white background on a normal blend mode. They would interact perfectly. However, If I took this image (removed under layer) and tried to add this trans PNG to a place in the web, here for example, on white, the outerglow would have lost it's blend.
This is particularly annoying on the website Im doing. One of the buttons had a light effect imageswap on a Java rollover thing. In PS the image interacted with the under layer (on Overlay blend IIRC), however it looks as though it's reverted to Normal on the website. And looses it's light cast effect. How could I get around this? Before the image was exported it had to be merged, upon merging though I can instantly see the change. As though all the blend modes have been reverted to normal.
2:
A slightly simpler one here
I know all about masking etc, however I have always wondered if you can actively mask layer effects. Again for simplicity I will use Outer glow as an example. Sometimes I don't want this all around a particular layer. But I want to keep the layer itself intact. Is there any way to mask the effect only, without having to copy bit of the image without the effect, on top of it to create the same result.
Apologies if I haven't made my point very well!
