1 - 5 of 5 Posts
Pinoy po mga koya
I've been trying to setup a dedicated physx card on a friend's amd pc.
he is using this board:
http://www.trustedreviews.com/mother...Motherboard/p3ASUS M4A89GTD PRO/USB3 890GX Motherboard Review
I can't get both cards working at the same time. I've tried everything from updating the bios. setting it to default, resetting the cmos etc. but when I use the nvidia card alone it works but when paired with his HD5850, windows can't detect it making it impossible to install any nvidia drivers at all.
any help will be greatly appreciated. TIA
EDIT:
no worries about the drivers, hacks. as you can see on my sig rig I got it working already. the prob is the nvidia card cannot be detected by windows when installed on the second pci-e slot.
I'm NOT new to Overclock
Pinoy po mga koya
Discussion Starter #4
no worries about the drivers, hacks. as you can see on my sig rig I got it working on my rig already. the prob is the nvidia card cannot be detected by windows when installed in the 2nd pci-e slot. this is for a friend's pc btw
Actually the nvidia driver disables physx if there are non nvidia cards present.
1 - 5 of 5 Posts
