Getting off stock
Need you whiz's to pick me a cooler that will fit in my sig rig
~$100
Cheers
~$100
Cheers
Yes, they are good, I've got mine and I get 4Ghz @1.28v and my CPU tops out at about 80c on prime95 blend and Intel burn test. This is on a single fan as well.Originally Posted by Uncle Dolans;15246096
Are those "Water Coolers" actualy any good? Also is the 212+ that little $30 cooler? (Never mind, i wrote this after you gave a link)
EDIT:
Wont fit man![]()
Interesting. Any reason the H80 over Antec's KUHLER 920?Originally Posted by compuman145;15246115
Fair enough, might pick up one of those "Water coolers". Unless that $30 cooler is really that amazing... However (Australian) going into summer and wanting to keep my clocks pretty good without overheating.Originally Posted by compuman145;15246157
No not really, I really like corsair, i've had 2 PSU's and 3 sets of memory from them and i've always had great quality equipment, Oh don't forget the case either.![]()
I've not used that alternative cooler, and corsair designed them in the first place so, the Kuhler920 wasn't released when I got mine![]()
Comps
The 212 is a great cooler for the price, It's pretty much the best cooler upto the $50 bracket, above that then it's good, but not as good by a fair length.Originally Posted by Uncle Dolans;15246228
Ahh ok, thanks. ++Originally Posted by compuman145;15246354
Comps
Why is that may i ask?Originally Posted by *********;15246472
H50/H70/H80 would work very well with your case.
212+ is an excellent choice too..(for its price range)
Because you have a single exsaust on your case which can take 120mm radOriginally Posted by Uncle Dolans;15246480
Why is that may i ask?![]()
