I've had many different cases and used almost a new once each time for each build I do for me or someone else.
I like the cases that are quiet in terms of noise, makes it seem like better quality but I don't want to spend a fortune. I have always had colored or black cases. I think I want a white one this time so that dust doesn't show up as much. Doesn't have to be black as in terms of the CM, but it is preferred. I think this will be a single GPU build, likely a Radeon 7900 series.
Choice one : NZXT Technologies H2 Classic Silent Midtower
Choice two : Fractal Design Define R4 (windowed) without window is $7 difference.
Choice three : Cooler Master 690 II Advanced
I would be open to a better suggestion if there is such a thing for this price range. Thanks for input!
