Picked up a 720 today
1305 Views 30 Replies 12 Participants Last post by  SilverPotato
I just got back from Microcenter with my new 720. Should I burn it in for a bit or go straight to overclocking
EDIT: Special Thanks to keenan, rewind, and zealot (and a few others) for helping me get my X3 720 unlocked and to the speeds of an X4 810
1 - 20 of 31 Posts
First thing you need to do is check if it unlocks to a quad !!!!!
haha, forgot about that
It won't
Try to unlock it to quad
and OC it to 3.6/3.8ish ~ : P
It won't
You are following guides right?....what voltages have you tried?
I tried -2% and it won't unlock all the cores
This is on stock 1.3V and 2.8GHz
It won't
Do you have the latest bios..?
Remember..
Set Advanced Core Calibration to "AUTO" and change "EC Firmware" mode to "Hybrid"
sometimes it needs more voltage to unlock, mine can at 1.4v but rather keep temps down a bit
Overclock it to max if you got only 3 core to make up for the 4th core.
Looks like I got all 4 cores @ 2.8GHz :O
Isn't stable though
Add
0.100V on the CPU
0.100V on the CPU NB.
0.100V on the NB
0.100V on the SB
That should help
How can I test the stability?
Boot into windows and run prime95 on blend
You will need to add voltage to get this baby going so keep us updated on the exact settings in your bios and how the stability testing works out
When you can go into Prime95 for at least an hour we are gettign somewhere
Keep in mind to be running everything else other than the core clock at stock and stable clocks/voltages
EDIT: Testing with some gaming ATM
Failed to stay stable with 4 cores @ 3.8GHz
And @ 3.7GHz
However 3 cores boots with 3.8GHz
And @ 3.7GHz
3.8Ghz is too much for a first overclock. Try to get it stable @ stock with 4 cores and more up 200Mhz. I got one @ 3.2Ghz unlocked with 1.375v
I've gone up in 200MHz steps from 2.8GHz and seemed to have stopped where I am
Prime95 crashes with 4 cores @ 3.7GHz 1.6V
3.6ghz would be your max I'm afraid...
I've had the same cpu and with 3 cores I got 3.9Ghz stable and 4 cores only 3.6ghz
Try 200 x 18 with 1.55V
1 - 20 of 31 Posts
