1 - 16 of 16 Posts
· Banned
I just thought I'd post a few pics of my rig. The blue LED fans look pretty nice, but the case is lacking. Also, I know this is a funny question, but can anyone tell what brand/model my case is just based on the pictures? The case was donated to me by a friend, and I have no idea what brand or model it is.
· Premium Member
looks nice, but u should get a cold cathode kit for it and you would be set!!! i cant tell what brand the case is, but whatever it is it looks nice...
· Banned
It's pretty dark where I took the pictures, so it really doesn't capture how bright these fans are. There's a pretty bad scratch on the front plate thing, so I thought about sanding and painting it. And yeah, I have some cold cathodes on my watched list on eBay and I'm seriously considering them. I'm also considering some LEDs. Which are brighter?
Cool case! If you're gonna plan on modding it though (might as well. It's pretty cool looking, was free, and has potential), I'd suggest modding your fan positionings if you can, or atleast adding some new spots so you have good airflow.
Can't wait to see the finished result either way!
· Banned
Discussion Starter · #9 ·
Yes I do have an XG Vortec, it says so in my system specs under my sig
. Also, those fans are Unincom, not Masscool. I don't think there's much of a difference between the two. Temps for CPU are 29C idle, 50C load. Mobo runs extremely cool, usually about 23C.
1 - 16 of 16 Posts
