1 - 3 of 3 Posts
⤷ αC
Open pamac
check boinc box
hit apply
commit dependencies
ADD USER TO boinc USER GROUP
start boinc service to generate rpc file , symlink , modify permissions
* Note that systemctl enable boinc.service is optional , it runs boinc on every boot
open boincmgr
proceed to add projects , Be sure to add yourself to the OCN team if you did not already
Thanks for the easy to follow guide. I have added it to the Guides and Tutorials Directory
:thumb:
The only thing that I would maybe suggest changing, would be to note that the "systemctl enable boinc.service" command is an optional step, that will automatically start the boinc daemon at boot.
⤷ αC
Confirmed working in Antergos with the Openbox Desktop environment
antergos-minimal-17.7-x86_64 install used
1. Right click desktop once installed ---> Applications ---> System Tools ---> Add/Remove Software
2. Install the packages from community repos
3. run the same commands as above
4. Log out and log in
5. Right click desktop ---> Applications ---> System Tools ---> BOINC Manager
6. Proceed to add projects
1 - 3 of 3 Posts
