1 - 3 of 3 Posts
Is this high ping when your computer is connected to the internet through a router, switch, etc, or is this with your computer directly connected to the modem?
If your ping is high connected directly to the modem then it is most likely out of your hands. You could try resetting the modem. You can also try calling and complaining to your ISP.
1 - 3 of 3 Posts
