Ping Reduction Needed
2456 Views 19 Replies 8 Participants Last post by  Traeumt
I can get my ping to stay bellow 300 (i live in thailand)
<250 would be great
any software or anything?
i saw a website for WoW you used a proxy for lower ping or something
1 - 20 of 20 Posts
I doubt a proxy would reduce your ping as it's another server the data has to be sent to, thus making it slower.
I don't think you can get software which reduces your ping but I can tell you to close ALL other software which is using your network, this should improve it a little bit.
Depends on where you're pinging to, but if it's anywhere out of Asia, best of luck, but you won't get it below 200-250ish.
k
the WoW thing talked about unsed under water cables or some thing
ill try killing any internet thing
PS no WIFI
Im playing crysis and Halo 1 online if that helps
It's called high speed internet, throw out that 14.4 dial up modem and stop keeping AOL in business. What does this have to do with pc games btw?
I don't recall the OP ever saying anything about using a 14.4k modem.
okey here is an alternative solution use proxy tunelling sofware www.your-freedom.net its very basic VPN program helping you to reduce HOPs while you are going overseas or somewhere else..
hop : points you ping for example you are pinging www.asdad.com and its located in usa there are at least 20 hops with the help of program its reduced to 15 .. try it and tell us if it works
btw ive reduced my ping ike 100 ms with this program and there are lots of Turkish users using this way
Theres really nothing you can do. If youre far away, then thats that.
nope mate not that easy believe me i had the same issue before i met with tunelling
i got 5 meg download from speed test and only 320kb upload
Try tunelling !
and u ll be surprised
btw if u just need ping reduction basiic your-freedom is great but if u need higher download capacity than 64kbit u have to pay.no need to pay unless you do other jobs than playing wow (about ping times and download
its downloading now
its downloading now
Okey i f u need any help regarding to program i am here
if this works +rep
if this works +rep
Are you going to play wow or surf web cause if u are going to play wow u need another tiny program beside that let me know
im going to play crysis and Halo 1
No WoW
its taking like an hour to find 1 thing and if it doesnt work then i haft restart is this normal
yes its searching for the server near you if u like to you can choose server manually and btw is there any proxy connection section for that games u want to play ? if no we ll use a program check it please (type the settings manually u can find details on the website prefer the closest server to you or lowest ms provier)
i am going to local dealer to get a new vga then ll be here just sort that program out thats what you are looking for i ll be back soon (try freecap or proxifier if that games doesnt support proxy connection)
I'm in thailand as well and I avg 250.
I only get 6 hours a day? and 18 total?
I might have to pay since I game 5 hours a day.
I am back Thai boys
no u dont have to pay reconnecting to server just works fine
1 - 20 of 20 Posts
