Hello,
I have planned the build as follows -
http://www.overclockers.co.uk/showproduct.php?prodid=CP-393-IN - CPU
http://www.overclockers.co.uk/showproduct.php?prodid=WC-001-OP - GPU x 2
http://www.overclockers.co.uk/showproduct.php?prodid=HD-109-OC - SSD
http://www.overclockers.co.uk/showproduct.php?prodid=WC-001-AS - Motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MY-083-GS - RAM x2
http://www.overclockers.co.uk/showproduct.php?prodid=WC-042-OE - Watercooling Set
http://www.overclockers.co.uk/showproduct.php?prodid=HD-385-WD - HDD's x2
http://www.overclockers.co.uk/showproduct.php?prodid=CA-054-OC - Power Supply
http://www.overclockers.co.uk/showproduct.php?prodid=CA-203-CM - Case
http://www.overclockers.co.uk/showproduct.php?prodid=BB-004-LP - Fan Controller
http://www.overclockers.co.uk/showproduct.php?prodid=CD-107-LG - BluRay Drive
http://www.overclockers.co.uk/showproduct.php?prodid=UP-017-AP - UPS
I am planning on water cooling a CPU, Motherboard and GPU x 2 - Would you advise If the water cooling set that I am planning on purchasing would be Decent enough? Will I need to purchase an additional radiator? For water cooling the two Graphic cards In SLI will I need any other equipment to link them together and water cool the both of them? What would be the best set up?
CPU > Radiator > GPU > GPU > Radiator > Motherboard?
Need advise If possible please. Also what's the best type of cabling and tubing that I could use In my system?
Kind regards
Jacob
Kind regards
Jacob
