Yeah, that stuff should work. Overclocking?
Why don't you go here (see Martin's stuff too) and do some calculations?
Originally Posted by billbartuska ![]() Yeah, that stuff should work. Overclocking? Why don't you go here (see Martin's stuff too) and do some calculations? |
Originally Posted by xArchAngelZerox ![]() Hey guys, I'm going to finally get my feet wet in the next few weeks, and I wanted some advice from you guys. Here's what I've got picked out: Radiator: Black Ice GTX 360 http://www.frozencpu.com/products/53...?tl=g30c95s161 Waterblock: Watercool HEATKILLER CPU Rev3.0 775 LT (I'd like the copper one, but I can't seem to find it for the 775 socket) http://www.sidewindercomputers.com/heatkillerlt775.html back plate: http://www.sidewindercomputers.com/hk775plate.html Pump: Swiftech MCP355 12v DC Pump http://www.sidewindercomputers.com/swiftechmcp355.html with XSPC Laing DDC Acetal Top http://www.sidewindercomputers.com/xsladdcactop.html Reservoir: Swiftech MCRES 2.0 http://www.sidewindercomputers.com/swmcmire2re.html Barbs: 8x DD Fat boys 1/2 http://www.jab-tech.com/Dangerden-FB...b-pr-4181.html Tubing: 15ft (I've heard 10-15 ft to be safe, I don't want to mess up and run out of tubing, but is this too much?) Primoflex 7/16 ID UV Red http://www.jab-tech.com/Dangerden-FB...b-pr-4181.html Primochill antikink Coils 5/8 http://www.jab-tech.com/PrimoChill-A...k-pr-4001.html I've already got high speed 120x25 yate loons, and I'm going to hold out for the lamptron fc 5 to match my haf 932, unless you guys can show me a fan controller that matches just as well. I've also got to grab some worm clamps...are there any special ones out there, or will the ones at home depot do just as well? What do you guys think? Eventually I'm going to add a GPU block to this loop, but a new GPU will come first, hopefully a 5870 =D Will this loop be able to handle a GPU block somewhere down the road? Thanks =D |
Originally Posted by Lysdexik ![]() The only place I've seen the 775 socket HK 3.0 in copper is in the UK, on sites like this: http://www.watercoolinguk.co.uk/cata...oducts_id=1694 It should be able to handle the 5870 when you get it, I run a 360 rad with low CFM fans and am able to efficiently cool my superclocked 260 and my i7 with temps in the low 30's for idle, and 60C load. I'm sure that rad will handle it, and if not you can always throw a 240 rad somewhere in the mix if your case allows for it. Most everything else looks great, but I would suggest getting these barbs instead: http://www.jab-tech.com/Bitspower-Tr...1-pr-4397.html Edit: you linked the fittings twice, once for the fittings and once under the tubing. The only other advice I can give is to spend a bit more money and get compression fittings instead of the bitspower, only reason I say that is because I had the same 7/16" Inner Diameter tubing that you linked, and found it difficult to clean out my loop. Even though the tubing fits snugly onto the barb being 1 size smaller and not necessarily requiring clamps, the tubing must stretch to fit onto the fitting and not to mention how hard it is to pull off of the fitting, but once it is stretched out.. you may feel the need to put clamps on to secure the tubing to the fitting. |
