Planning on Watercooling my i7
249 Views 2 Replies 3 Participants Last post by  jam3s
Just ordered the parts I held off on the TRUE for a little bit to look into water cooling I was wondering if I just wanted to cool my CPU with water first and upgrade to CPU, Video cards later what would be the minimum to buy?
1 - 3 of 3 Posts
basically everything juggalo said.
You'll need:
pump, radiator, cpu-waterblock, reservoir or tee line, fans for the radiator, tubing (either 1/2" or 7/16"), distilled water (can be bought at your local grocer) and uv dye and some sort of biocide (pt nuke) and 1/2" fittings.
I would recommend everything that juggalo quoted for you... the MCP655, Feser TFC 360 rad, apogee gtz, either the swiftech mc-res micro v2 or the DD dual bay res, and I would highly recommend the Yate Loon D12SM-12 Medium Speed fans.
I also would recommend that you use Petras for all your watercooling needs. Great customer service and they know their stuff.
jam3s
1 - 3 of 3 Posts
