1 - 6 of 6 Posts
733hz
Assuming UV lights on all the time didnt help, but ive noticed my tubed have gone hazy when put under bright light. I currently am using XSPC's lrt uv blue/clear tubing, with feser one (yeah i know it was a bad decision in hindsight)
Does anyone have any recommendations for a Plasticizer free tubing, or one that is at least resistant to clouding? I will probably end up draining my loop and putting in distilled water and a kill coil at this point. and using dyes if i really want to.
Primochill Advanced LRT is supposed to be plasticizer free. If you go with a dye, the only one I would trust using is Mayhem's
Primochill Advanced LRT is supposed to be plasticizer-free. It's one of the reasons I'm using it on my setup - from what I researched, it looked like there were many users that were happy to report no plasticizer build up.
My tubing is black, so I can't tell for sure if there's any plasticizer build up without taking it apart, otherwise I would check for you.
Edit: morencyam beat me to it.
Originally Posted by 15goudreau View Post
I will third this. I use Mayhem's Pastel with primochill advanced LRT and that is the only tubing I trust besides hard acrylic.
I also have used Primochill advanced LRT, in my own build and in my housemates. Works like a charm no complaints at all and no plasticizer build up.
1 - 6 of 6 Posts
