my water cooling list:
http://i54.tinypic.com/orth86.png
concerns and questions:
1. What case should I get so I can fit everything inside including the 360 rad? I was looking at the HAF 932, but the side window is not very show-off-friendly, lol. But I will probably end up getting that one since it's the cheapest?
2. So I need a clamp on every barb right? Does that res+pump top combo come with barbs? It didn't say. Those plastic blue UV clamps sure look good but it's plastic, are they reliable?
3. That waterblock should fit my GPU right? This is the GPU I have, two of them.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130480
I should probably get a tube of thermal paste too right?
Got any other cheap/good GPU blocks that will fit my card? full coverage.
Thanks!
Thanks!
