this is what it's at right now, but I'm still lost on what to do. And taking 2 sticks out made it stable. Thanks to everyone that helped out I will rep you soon
CPU-Z Report
CPU-Z version 1.31.
CPU(s)
Number of CPUs 1
Name AMD Athlon 64 3700+
Code Name San Diego
Specification AMD Athlon(tm) 64 Processor 3700+
Family / Model / Stepping F 7 1
Extended Family / Model F 27
Brand ID 4
Package Socket 939
Core Stepping SH-E4
Technology 90 nm
Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE, SSE2, SSE3, x86-64
CPU Clock Speed 2508.7 MHz
Clock multiplier x 11.0
HTT Bus Frequency 228.1 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 1024 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 2508.7 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 128 bits
Mainboard and chipset
Motherboard manufacturer ASUSTeK Computer INC.
Motherboard model A8N-SLI Premium, 1.02
BIOS vendor Phoenix Technologies, LTD
BIOS revision ASUS A8N-SLI Premium ACPI BIOS Revision 1009
BIOS release date 10/21/2005
Chipset nVidia nForce4 rev. A3
Southbridge nVidia nForce4 MCP rev. A3
Sensor chip ITE 8712
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory
DRAM Type DDR-SDRAM
DRAM Size 1024 MBytes
DRAM Frequency 228.1 MHz
FSB
RAM CPU/11
CAS# Latency 2.5 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 8 clocks
Bank Cycle Time (TRC) 16 clocks
DRAM Idle Timer 16 clocks
# of memory modules 2
Module 0 Corsair DDR-SDRAM PC3200 - 512 MBytes
Module 1 Corsair DDR-SDRAM PC3200 - 512 MBytes
Software
Windows version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX version 9.0c
