Please help a noob with a memory overclock
625 Views 12 Replies 5 Participants Last post by  Bennylava
I have taken my little e4300 about as far as i am comfortable with. 3.1Ghz with a voltage setting of 1.3625 and prime95 temps of 67c after an hour. (coretemp's VID says 1.325v, i guess this is vdroop i am seeing here?) Anyway, i would like to start on my memory overclock now that i have gone as far as i can with the CPU. This is the overclock method that i have learned from countless hours of reading forums and guides. Well, here is a pic of my bios with the memory settings that i currently have set up, please tell me if there is anything you would change in order to overclock the memory better/further.
As you can see, i pretty much have it set to the stock settings of typical 1066 memory. (although the memory is currently only running at 1026 or something like that, it changed when i upped my CPU by 100Mhz) Is there anything that i can improve here? I am afraid i am not sure what all those settings are at the bottom under **ADVANCED MEMORY SETTINGS** The top i have set to 5,5,5,15 (with a CMD of 2T, i guess that mean 2 commands per clock) and the bottom is set to:
tRRD: [Auto] - 4
tRC: [Auto] - 30
tWR: [Auto] - 6
tWTR: [Auto] - 10
tREF: [Auto] - 7.8uS
From what i have read, the 30 in the tRC field needs to come down to about 24, correct? Also, if you see anything else or have any other suggestions, i would be happy to hear them. Thanks- Benny
1 - 13 of 13 Posts
Here are a couple more pics just in case they are needed...
Um... dude, set everything manual so that it is is 5-5-5-15 and do not set the CMD to manual (except the advanced memory timings, leave those auto). Then go and try to knock one down at a time and test it with memtest. Then go and another one until you reach 4-4-4-15 and so forth. Then try 12 so it will be 4-4-4-12.
So everything except the main timings at the top get left to auto? Am i to understand that you never need to mess with those "Advanced memory settings" when overclocking your memory?
Okay first things first. If you dont already have it get the latest version of Memtest. You will need to make a bootable CD with memtest.
According to Kingston's website your RAM is rated for 5-5-5-15 at 2.2v. Please correct me if that is the wrong kit.
Start by bringing your RAM voltage up to 2.1v. You can try 2.2v later if you want, but I am not sure it will give you too much more. Set your RAM to 5-5-5-15 manually and leave tRC on Auto for now. Now start raising the speed of your RAM in the BIOS. You might have to make large increases due to the way the 750i chipset sets ratios even if you set the RAM to unlinked. That is the reason you see your RAM running at 1033 even though you set it to 1066.
After you raise the speed of the RAM boot into Memtest and let it run for at least one pass. If it passes go back into the BIOS and increase the speed again until Memtest starts showing errors.
After you find your highest stable speed you can go back a start fooling around with the timings. The lowest you can set your tRC is the sum of tRAS+tRP. So if you use 5-5-5-15 it would be tRC=20. Test that with Memtest and if it passes try lowering the first 4 timings. You probably wont be able to lower tCL, but the others may come down a little and will show improvements at least in benchmarks.
For example I run my 2x2GB Corsair RAM at 5-4-4-12 with a tRC of 24. The important thing to remember is when you start fooling around with timings, if you boot into windows and its not stable you can corrupt your OS. So be very careful with those.
Thanks man, that explanation really helped me out a lot.
But yeah i do find it to be kind of a pain in the rump, to not be able to set my FSB:Memory ratio even with it set to "Unlinked".
The tRC value can be determined by adding the tRAS + tRP (5-5-5-15) timings together. So, in your case, you can lower to 20.
http://www.techpowerup.com/articles/...D/memory/131/2
you guys have helped me out a lot, and i really appreciate it. My next question would be, is the fact that i can't control my divider going to hurt my overclocking ability? I mean i can, but then everything gets set to auto and i lose all of my memory settings/overclock. I looked at my FSB:Memory ratio and it has it set to 5:7. I have heard before that 1:1 is the most desirable for overclocking purposes due to it yielding the most performance. Any truth to this?
I have learned one thing though, there is a lot more to overclocking RAM then there is to OC'ing a CPU lol.
Change your avatar before it shoop da oops all over your memory controller or something
Most people think its odd that the mobo will just pick its own ratios, but it really does give you more options for OC'ing the RAM. Unlike intel chipsets which are limited to just a few ratios the nvidia are almost unlimited. I think im running 5:13 at the moment.
I think a lot of people dwell on the "magic" 1:1 ratio. My advice dont. Just find the highest speed you can run the RAM at, and most of the time that will give you the best performance.
Yes there is a little more to OC'ing RAM then the CPU, but thats just part of the fun.
Ok then. But is it safe to have varying numbers in your RAM timings, like you might have when trying to find your ideal overclock? For example, 5-5-5-15. Or some people do 4-4-4-12. Well it occurs to me that 5+5+5=15 and 4+4+4=12. What if you threw a different number in there like: 4-5-5-15 or 4-3-4-12? Would that screw anything up? This is something i think i will have to do in order to find the lowest timings that i can run. And someone made a comment about the TRC being able to corrupt your OS so i was afraid to go playing around with the timings to much without asking first.
Most of the numbers dont need to be the same, and like you already guessed to get the most out of the RAM they probably wont be the same. For example I have run RAM at 4-3-3-9, 5-4-4-12 and 5-4-5-18 and they were stable. Probably the most important performance settings are tCL, tRCD, tRAS, and tRC.
The only two I am aware there is some type of formula for are tRC and tRAS. These formulas are to figure out the absolute lowest you can go.
tRC= tRAS+tRP
tRAS= tCL+tRCD+2
I was the one who mentioned that messing with timings can corrupt your OS. Which is why I always recommend testing with Memtest before booting up the PC.
Good luck and try not to brick your PC.
It also seems to me that there is a bit of a balancing act going on. Cause i would love to run my RAM at 1200Mhz, with timings of 4-4-4-12 and a tRC of 17. But that's not going to happen, is it?
Still, as an overclocker, i have to try...
1 - 13 of 13 Posts
