ok im building myself a conroe rig and im considering getting WC instead of air, i do plan on doing some ocing. im getting a E6600 and i plan on sticking that in a P5B Deluxe with some crucial ballistix ddr 1000. im considering upgrading to WC at the same time. I want something that i can easily upgrade, at first im only gonna be using a x1950 pro, probably the HIS, so i think im prob only gonna be wcing the cpu but at some point want to add blocks for the graphics card and bridges.
im fine buying either a ready kit or putting something together myself, like to use hands on learning lol. putting something together myself might make it easier to upgrade later on but i donno.
so please recommend a good beginning set-up and try to keep it under $200 but if u dont think i can get something good for that much then go higher
