Hello, Im saved enough money so its about time to upgrade my 5yrs old pc, going from air to water. Its my 1st time doing it so I need some assurance that my loops run correctly. I plan to run 2 loop seperately 1 loop for GPU and the other for CPU+Mobo.
For CPU and Mobo i have one 360rad and one 240rad: Res -> Pump -> 360rad -> CPU -> 240rad -> Mosfets/Chipset -> Res
For GPU i have one 480rad and two 1080ti: Res -> Pump -> Rad -> GPUs -> Res
Is it good idea to use 4 pumps, one dual pump for each loop? for redundancy in case if one was to stop working
Thank you!
Thank you!
