1 - 5 of 5 Posts
alright fellas,
i just took out my soundblaster live 5.1 card, and decided to just use the integrated sound on my abit is7
i have 4.1 speakers - and i have installed the latest audio driver for the mobo - but i can only hear the rear 2 speakrs?
can anyone tell me what is going on?
Linux Guru
Originally Posted by shermstix
Did you change your settings in the windows control panel?? That is where you will have to change your options to a 5.1 set-up.
Actually for the integrated sound for the IS7 you must change the settings in the Sound Manager which is included on the mobo install disk. The sound manager gives you many good setting, a mixer, sound effects, and multiple speaker modes to use.
True, you probably need to change it there
, but you will also need to change it in the Windows Control Panel (start>control panel>sound and audio devices>advanced>speaker set-up), unless the sound manager does it 4 ya.
Linux Guru
The sound manager integrates with the Windows settings, it should change the setup for you.
1 - 5 of 5 Posts
