1 - 6 of 6 Posts
Am looking to buy a monitor for mainly gaming and multimedia tasks have shortlisted 4 monitors! If possible can someone please tell me which monitor to get and why? thanks for your time and help!!!!
1. AOC Razor E2343FK 23 Inch LED Widescreen Monitor Black
* Cabinet Colour: Black
* Screen Size: 23"W
* Viewable Image Size: 58.42cm
* Brightness: 250 cd/m²
* Contrast Ratio (typical): 50000000:1 (DCR)
* Response Time (typical): 5ms
* Viewing Angle: 170/160 (CR≥10)
* Scan Frequency: H: 30K~83KHz V: 55~75Hz
* Pixel Frequency: 148.5MHz
* Recommended Resolution: 1920Ã[email protected]
* Display Colours: 16.7M
* HDCP Compatible: Yes
* Input Signal: Analog RGB and DVI-D
* Input Connector: 15-pin D-Sub and 24-pin DVI
* Plug & Play: DDC 2B/CI or VESA DDC2B
* User Control: Auto, left, right, Menu, Power
* OSD Languages: 14 Languages
* Speakers: No
* Wall-Mount: Yes
* Mechanical Function: Tilt: -3°~12°
2. ASUS VE246H 24" Widescreen LCD Monitor
TFT-LCD Panel Panel Size: 24" Wide Screen (16:9)
True Resolution: 1920X1080
Pixel Pitch: 0.277mm
Brightness(Max): 250 cd/㎡
Contrast Ratio (Max.): 50000 :1 (ASCR)
Display Color: 16.7M
Viewing Angle (CR≧10): 170°(H)/160°(V)
Response Time: 2 ms (Gray-to-Gray)
Video Features Trace Free Technology
SPLENDID Video Intelligence Technology
SPLENDID Video Preset Modes (5 modes)
Skin-Tone Selection (3 mode)
HDCP support
Color Temperature Selection(5 modes)
Audio Features Stereo Speakers 1Wx2 stereo RMS
Convenient Hotkey SPLENDID Video Preset Mode Selection
Auto. Adjustment
Brightness Adjustment
Volume Adjustment
Input Selection
Input / Output PC Input: DVI-D/D-Sub
PC Audio Input: 3.5mm Mini-jack
Video Input: HDMI
AV Audio Input: HDMI 1.3
Earphone jack: 3.5mm Mini-jack
3. BenQ GL2430HM 24 Inch Widescreen LED Monitor with Speakers
The BenQ GL2430HM 24" widescreen LED monitor features a 1920 x 1080 full HD resolution with a 2ms response time, DVI and HDMI inputs, 12M:1 dynamic contrast ratio, tilt adjustable stand, 170/160 viewing angles and built in speakers. 3 year warranty.
4. Samsung 2233RZ 22" Widescreen 120Hz LCD Monitor
* 1680x1050 Native Resolution
* 300 cd/m2 Brightness
* 20,000:1 Dynamic Contrast Ratio
* 170o/160o (CR>10) Viewing Angle
* GTG 3ms (3D) / 5ms(2D) of Response Time
* 120Hz Dual Engine
* HDCP (High-Bandwidth Digital Content Protection)
* DVI-D (Digital Interface)
Not really looking to use the 3d just interested in the 120 hz.
So these are the four all from PC Case Gear.
Once again thanks for your opinion.
And if you know a better one than these four please suggest $250-$350 bracket.
would defo go for the samsung one, all the mointers ive used/seen ive allways thought smasung has better picture quailty and looks nicer
1 - 6 of 6 Posts
