Hi every one, This is my problem and i need a fast help please since i already ordered my stuff and i need to cancel it if i made any mistake..
My currant cooling lob ruining (Pictures Attached)
- x1 Valve at 1/2" i am using it with my CPU
- x2 Empty valves at 1/4" (I am planing to use it with my new stuff)
My new items which i am planing to add to my currant lob are:
- x1 XSPC RX360 Rad.
- x2 1/4" Thread Barb Fitting for 1/2" ID Tubing
- x1 Primochill 1/2" ID - 3/4" OD (13-19mm) Tubing
- x1 Full cover dd gtx 285 with 1/2" barb.
My problems is clear, i ordered 1/2" ide Tubing to fit my Rad and Vga block, but i forget that i have 1/4" valve to be use with.
1- Should i continue with my order and buy some jointer between the 1/4" and the 1/2" tube?? Like this:
- http://www.advancedfluidsolutions.co...ner-1176-p.asp
or
- http://www.hosefit.co.uk/catalog/index.php?cPath=149
2- Should i cancel me order for the 1/2" tubing/barbs and buy 1/4" one??
3- Any other advice from any expert person in watercooling.
Please Help me!!
Thank you very much.
or
Please Help me!!
